AutoCAD Plant 3D General DIscussion
Active Contributor
TBoo
Message 1 of 5 (260 Views)
iso border attributes
260 Views, 4 Replies
02-24-2012 01:04 PM
I am having a hard time with the attribute justification in the iso border setup. Everything works pretty good just when I create the iso the border attributes are not in the place I put them such as center justified. Some are pushed over to the left a little bit which kinda creates a problem. If I double click the attribute and edit the justification to… lets say left the text moves and then select back to center, the text moves to the place where it should have been in the first place. It kinda makes that little tool useless to me. Could I may be doing something wrong? Is there a tutorial or something else out there somewhere?
Member
ian.whistler
Message 2 of 5 (235 Views)
Re: iso border attributes
02-27-2012 06:26 PM in reply to: TBoo
Apparantly its a bug, mine does the same, just grab everything, move it slightly and it seems to fix it.
Active Contributor
TBoo
Message 3 of 5 (222 Views)
02-28-2012 12:25 PM in reply to: ian.whistler
The only thing with that is if you edit the text it will go back where it was supposed to be. which is now further to the right than where you wanted it to go in the first place. An Autodesk personnel needs to look in to this little bug.
ricardo.janesko
Message 4 of 5 (182 Views)
04-23-2012 06:56 AM in reply to: TBoo
Someone found a solution to this? In Plant 2013 this also happens.
rclipc
Message 5 of 5 (87 Views)
05-30-2013 03:26 PM in reply to: ricardo.janesko
I'm having this same issue in P3D 2013 SP1.  The easiest fix I've found is after the isos are generated to use ATTSYNC and update your titleblock.  This should move all of your attributes to the correct location.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
