AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
ISO Annotation Leaders
2 REPLIES 2
KEY_Engineering_Stacy_Coggin
565 Views, 2 Replies
Is there a way to make the annotation leaders point closer to what they are pointing at? And, can you control the placement of text on the leaders more? This is a great program but the output of the ISO's is a bit SLOPPY.
2 REPLIES 2
If you are using the new Plant 3D 2012 Isometric generation currently there is no setting to control the leader line distance. From what I have seen if the mleader settings are changed in the Iso config this issue shows up. Is that the same scenario you are running into?
Thank you,
Jason Drew
Designated Support Specialist
in reply to: jason.drew
Any improvements on this in 2013 Jason? I have not messed with mleader at all and they are not coming out right.
They are not only too far away but most of them have a horizontal or vertical line that shoots away from the leader text.
”Boost
