I use a keyboard macro for changing the views when I am drawing
eg -view o t ( change the view to front ) which changes the USC from WCS to unnamed.
the problem is, when I forget to reset the UCS to WCS it wrecks havoc with XREF's
is there a keyboard command to set it to the UCS to WCS?
Solved by jabowabo. Go to Solution.
You could just append to your macro like so:
-view o t ucs w
Perfect.
-view o f
-view o l
-view o r
and when i'm done one keystroke for
-view o t ucs w
and now it's reset, and xref's will not be messed up..
having to go back through a dozen drawings, resetting BASE, then moving them all around so that they connect...
I use to just have everything in one drawing, and basically did not use xref's often.
