AutoCAD Plant 3D Forum
Is there a command to reset USC to WCS?
2 REPLIES 2
JohnHolder
1004 Views, 2 Replies
I use a keyboard macro for changing the views when I am drawing
eg -view o t ( change the view to front ) which changes the USC from WCS to unnamed.
the problem is, when I forget to reset the UCS to WCS it wrecks havoc with XREF's
is there a keyboard command to set it to the UCS to WCS?
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
2 REPLIES 2
jabowabo
in reply to: JohnHolder
You could just append to your macro like so:
-view o t ucs w
JohnHolder
in reply to: jabowabo
Perfect.
-view o f
-view o l
-view o r
and when i'm done one keystroke for
-view o t ucs w
and now it's reset, and xref's will not be messed up..
having to go back through a dozen drawings, resetting BASE, then moving them all around so that they connect...
I use to just have everything in one drawing, and basically did not use xref's often.
Master Yoda.
”Boost
