AutoCAD Plant 3D Forum
Is it possible to erase the second flange but keep gasket and bolts
3 REPLIES 3
PatrickByrne
548 Views, 3 Replies
At the end of a pipe i need to keep the bolts and gaskets, is it possible to erase the second flange but keep the bolts and gaskets.
We could add in a piece of equipment and continue from that but I just want to know if it is possible.
3 REPLIES 3
you can make the second flange in the properties status = existing (normally status=new)
Thanks, it solved my problem too.
Arun_Kumar_K
in reply to: Arun_Kumar_K
Similar to this, I have an issue in P&ID. How to keep the "Other vendor scope" lines and valves away from valve schedule and line list.
”Boost
