AutoCAD Plant 3D General DIscussion
Active Contributor
cad.westie
Message 1 of 6 (867 Views)
Insulation Problem
867 Views, 5 Replies
11-21-2010 07:50 PM
Does anyone know why the insulation looks misaligned with the elbow centerlines (see attached image) ? It only seems  to do this on my elbows where the radius is smaller than the elbow length ie the elbows have a small straight at each end.
Peter
This should have the same values, are these customized elbow?
Contributor Bob
Bob
Message 2 of 6 (789 Views)
Re: Insulation Problem
11-29-2010 10:15 AM in reply to: cad.westie
Which snap are you using when placing the insulation symbol?
Active Contributor
cad.westie
Message 3 of 6 (786 Views)
11-29-2010 11:38 AM in reply to: cad.westie
I am not attaching insulation to the line I am selecting the line and then in properties pallette applying an insulation type & thickness to it. I believe the problem is due to the elbows having a straight stub on each end and the insulation doesnt seem to allow for this.
Regards, Peter.
Valued Contributor
neonade
Message 4 of 6 (504 Views)
07-14-2011 07:12 PM in reply to: cad.westie
Member
bartosz_przychodniak
Message 5 of 6 (414 Views)
10-11-2012 06:55 AM in reply to: neonade
Has anybody another idea? I have the same problem, and radius in spec editor isn't a solution of the problem.
Member
Message 6 of 6 (401 Views)
10-11-2012 11:53 PM in reply to: cad.westie
Sorry for a mess. After some more tries the solution is working. I forgot to account fasteners in radius value.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
