AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Insulation Problem
5 REPLIES 5
cad.westie
1669 Views, 5 Replies
Insulation Problem
Does anyone know why the insulation looks misaligned with the elbow centerlines (see attached image) ? It only seems  to do this on my elbows where the radius is smaller than the elbow length ie the elbows have a small straight at each end.
Peter
5 REPLIES 5
Bob
in reply to: cad.westie
Which snap are you using when placing the insulation symbol?
cad.westie
I am not attaching insulation to the line I am selecting the line and then in properties pallette applying an insulation type & thickness to it. I believe the problem is due to the elbows having a straight stub on each end and the insulation doesnt seem to allow for this.
Regards, Peter.
neonade
This should have the same values, are these customized elbow?
Has anybody another idea? I have the same problem, and radius in spec editor isn't a solution of the problem.
Sorry for a mess. After some more tries the solution is working. I forgot to account fasteners in radius value.
”Boost
