Does Cadison inherit the properties from plant 3D? In any case the output drawing would be in dwg format then why export to autocad. By using this command it would become autocad 3d objects.
If cadison take all properties from plant 3d drawing then we can check why insulation is not coming in it.
hi,is there any new concerniong the insulation in the exported dwg file? we have the same problem.
When you give out the 3D model to company involved in the pipe support construction you must have the insulation visible.
thanks
mauro
