AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Insulation color
2 REPLIES 2
snijdam
2251 Views, 2 Replies
Insulation color
My insulation is created in a separate layer called: pnp3dinsulationlayer   All of the insulation has the same color. Iwat to see in Navisworks the insulation by layer/pipe. The insulation should be the same color as the pipe. In an othe project of mine it is correct.
How to resolve this problem?
2 REPLIES 2
Hello Stephan,
Two points:
Inside of Plant 3D you can do this in the project configuration. Switch to the node 'Layer and Color Settings'. Here you assign the color for example depending on the layer or for the insulation type. If you use layer the second setting is important for you: Assign layer by... for example short description. See attached snapshots.
In Navisworks: There is an issue with insulation in Navisworks. The development is currently working on it.
Regards
Bernd
Bernd G.
Senior Product Support Specialist
Has this issue been fixed??
Regards
Bernd
Bernd Gerstenberger
”Boost
