AutoCAD Plant 3D General DIscussion
Valued Contributor
3 Kudos
Post 11 of 20
Re: Instruments in BOM
07-31-2012 11:06 PM in reply to: Rcfuss
I find the answer.
Still in isoconfig.xml file, in the setcion of <AnnotationSchemes></AnnotationSchemes>
add in this:
<ComponentSchemeName="Instruments"AnnotationStyle="Circle"Tag="XX"Alignment="FlatHorizontal"LeaderStyle="Always"Components="Instrument"Filter="Instrument"Fields="PartNumber" />
I put it almost in the end of <AnnotationSchemes> myself.
And it works. Hope it works for you too.
Valued Contributor
0 Kudos
Post 12 of 20
08-01-2012 04:58 AM in reply to: Arch_art
Thank you for looking at that.
Valued Contributor
4 Kudos
Post 13 of 20
08-09-2012 01:31 AM in reply to: karthik.nathan
The instruction in doing the copy and paste for the instruments seems quite tricky but it works.
Valued Contributor
4 Kudos
Post 14 of 20
08-09-2012 07:28 PM in reply to: Arch_art
Is this possible for the part id to be adjacent with the Pressure Indicator call-out.
Aside from that the dimensions rule for vents and drain is not anymore recognized when you placed custom instrument.
17 Kudos
Post 15 of 20
05-06-2014 01:23 PM in reply to: karthik.nathan
Old thread - but I was following this and I can't seem to get the instruments to show up in my list if I have my BOM table set-up to 'Simple BOM' style.  If I change the table format to 'Grouped with category titles', it places the instrument information into the BOM.
How can I get a simple BOM with the instrument information included?
Active Contributor
4 Kudos
Post 16 of 20
05-15-2014 02:51 PM in reply to: Arch_art
Arch_Art,
It seems that there are some typos in the code you provided, could you proof it real quick? I can't get it to work, even after editing for spaces.
Plant 3D 2014
Dave
Valued Contributor
4 Kudos
Post 17 of 20
05-23-2014 02:41 AM in reply to: karthik.nathan
karthik.nathan wrote:
Hi Omar,
The IsoConfig.xml looks perfect! There is, however, one other thing you need to do. Now, that you have a way of identifying & grouping instruments, you will need to 'define' an area (or a row template) in your Iso.dwt template file so that the iso engine knows that it has to populate that area with the newly created instruments group. If you open up the Iso.dwt file, this is what it would look like.
BOM template
Just copy and paste the 2 rows for 'VALVES <valves>' and rename it to 'INSTRUMENTS <instrument>'. The value in the angle brackets is the label that helps identifies what components should go in there (This SHOULD match the label in the newly created group in IsoConfig.xml)
That's it. Try it out and let me know. Hope it works!
-Karthik
Hello  Karthik,
I tried as per your suggetion.
But I cant get it in BOM..
Please see snapshot..
Please give me some tips for further move.
Thanks in advance.
-Regards
Prag
Valued Contributor
4 Kudos
Post 18 of 20
06-06-2014 01:37 AM in reply to: paragnewe
dear All,
Any clue?
-Regards
Prag
33 Kudos
Post 19 of 20
06-06-2014 05:56 AM in reply to: OmarGT
Hmm? Instruments in iso bom or bom report?? As far as I know, putting the right skey and the block for it in the iso solves the problem..
Best Regards,
Pat Andres
Autodesk Expert Elite
CAD System Administrator
Freelancer
Valued Contributor
4 Kudos
Post 20 of 20
06-06-2014 09:31 PM in reply to: patpat79
Instruments in iso BOM...
I have add proper SKEY to instrument.
I tried to add instrument group into ISOconfig.xml
but whenever i add "instrument group" .. then iso will not generate and it will give an error.
i dont understand this mis-behave of acad...
-Regards
Prag
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
