AutoCAD Plant 3D Forum
Instrument Tags on PID DWG's not printing correctly
3 REPLIES 3
jwedeking00
1264 Views, 3 Replies
I'm using Plant 3d 2012 and I am having trouble printing the instrument tag wipeouts when using plant 3d.  I've ensured my textmask variables are set correctly however this still does not work.
(I posed this in P&ID Forum however this seems the proper venue)
3 REPLIES 3
in reply to: jwedeking00
I'm having the same issue with longer tags.  The mask seams to be plotting after the circle.  I edited the default annotation block from Project Setup and changed the standard text style to ROMAN S and 0.8 Width Factor.  It looks fine on screen, but plots incorrectly.
jwedeking00
About two weeks ago I received an e-mail from Autodesk through my CAD support proxy...Autodesk says they are pushing for a fix as soon as possible however they have given no indication how much time this will take or an actual guarantee that a hotfix will come out for this problem.  Hopefully they will issue a fix for this instead of making us wait for Plant 3D 2013.  I can tell you that the wipeouts worked correctly in Plant 3D 2011.  Thanks
The drawing order of the Wipeout objects in the instrument block have to be above the instrument symbol outline (i.e. the circle), but behind the instrument text.  If the instrument outline is changed through block editing by resizing, changing color, etc, then this moves the draw order above the Wipeout Object.
While editing the annotation block through Project Setup, change the drawing order of the instrument symbol to "back", but use the "Send Under Objects" command not "Send to Back."  For some reason "Send to Back" doesn't always work.
DGrant
”Boost
