AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Installation of spec editor 2014 after plant 3d is installed
7 REPLIES 7
Message 1 of 8
berimahcroffie
683 Views, 7 Replies
I installed Plant 3d 2014 on a pc for one of my colleages a few months ago without the spec editor.
In the meantime he has grown expirience with the software and i wanted to install the spec editor afterwards.
Is this possible? I can't find it anywhere in the current installation and when i try to install again it says plant is already installed.
Thanks in advance.
7 REPLIES 7
Message 2 of 8
Default Plant 3D installer should install Spec & Catalog editor. Can you go to the following location and look for this file.
C:\Program files\Autodesk\AutoCAD 2014\PLNT3D\SpecsAndCatalogsEditor.exe
If you don't see this exe file, do let me know.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Message 3 of 8
The exe file you specified is missing.
I know it is installed by default, but during the installation you can uncheck the box of the spec editor so it isn't installed along with plant 3d.
I unchecked that box and that's the reason it isn't installed. The problem is I can't get it installed afterwards.
Is the exe-file the only thing the spec-editor needs? Because than I can copy it from another pc where it is installed and put it in the directory you specified. Will this work?
Kind Regards,
Corn? van Stee
<< Please read our E-mail Disclaimer at: Emaildisclaimer.Grontmij.com >>
Message 4 of 8
As for as I see, its just an exe file which i highlighted . You may want to try copying it to the path i mentioned earlier.
If it doesn't work, you may need to consider doing a clean uninstall/reinstall of the product as there isn't anyway to install only spec editor after Plant installation.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=14116967
Hope it helps. let me know, if you need more info.
Message 5 of 8
I copied the following files:
SpecsAndCatalogsEditor.exe.config
SpecsAndCatalogsEditor.resources.dll
Plant 3D 2014 Spec Editor.ink from the start menu.
This doesn't work.
Uninstalling plant 3d doesn't work because the uninstall gives an error "Invalid Drive K:\"
Searching the register for K:\ comes up with nothing.
Do you have an alternative solution?
Kind Regards,
Corn? van Stee
Message 6 of 8
I believe you have installed Plant 3D 2014 extension 1 as well. Can you try the uninstall as per the solution described here.
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Uninstalling-Plant-3D-2014-Extension-1/td-p/4351720
Do let me know, if it doesn't work.
Message 7 of 8
I haven't installed the extension because i can't get it to install.
I put a discussion on the forum for that as well.
With the installation of the extension I get the k:\ drive error as well.
Kind Regards,
Corn? van Stee
Message 8 of 8
It seems that you have a wrong registry entry here. Try to uninstall P3D using Microsoft FixIt: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21891972&linkID=12305695
Regards
Bernd G.
Senior Product Support Specialist
”Boost
