I installed Plant 3d 2014 on a pc for one of my colleages a few months ago without the spec editor.
In the meantime he has grown expirience with the software and i wanted to install the spec editor afterwards.
Is this possible? I can't find it anywhere in the current installation and when i try to install again it says plant is already installed.
Thanks in advance.
Default Plant 3D installer should install Spec & Catalog editor. Can you go to the following location and look for this file.
C:\Program files\Autodesk\AutoCAD 2014\PLNT3D\SpecsAndCatalogsEditor.exe
If you don't see this exe file, do let me know.
As for as I see, its just an exe file which i highlighted . You may want to try copying it to the path i mentioned earlier.
If it doesn't work, you may need to consider doing a clean uninstall/reinstall of the product as there isn't anyway to install only spec editor after Plant installation.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=14116967
Hope it helps. let me know, if you need more info.
I believe you have installed Plant 3D 2014 extension 1 as well. Can you try the uninstall as per the solution described here.
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Uninstalling-Plant-3D-2014-Extension-1/td-p/4351720
Do let me know, if it doesn't work.
It seems that you have a wrong registry entry here. Try to uninstall P3D using Microsoft FixIt: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21891972&linkID=12305695
Regards
