AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Installation of 2014 PLANT3D
2 REPLIES 2
Dadspackard
495 Views, 2 Replies
Can I install 2014 PLANT3D when I have ACAD 2011, 2012 and Bentley AutoPLANT installed on same workstation?
Tom
Tom
aka, Dadspackard, Packin31
2 REPLIES 2
blorich
in reply to: Dadspackard
As long as you have the room for it on your hard drive.  make sure tha you install 2011 first, then bentley autoplant (then run bentley so it associates itself with 2011 and no other program) then 2012, then P3D 2014.  Biggest issue I have always had is Autplant trying to open with newer versions of Autocad. But if you install them in correct order you will be fine.
Dadspackard
in reply to: blorich
Blorich,
I have 2011 and 2012 and AutoPLANT install already and running
Wanted to give the new PLANT3D a run.
I appreicated your input
Thanks for the help.
Tom
”Boost
