AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Incorrect elbow direction on isometric
4 REPLIES 4
Ahmed1081975
458 Views, 4 Replies
Hi Autodesk Supports,
I have problem when generating the isometric for elbow welding
direct in another elbow, I don't know what is the problem is there
for more clarification refer the attached file
Ahmed Helal
4 REPLIES 4
Dear Ahmed,
Please, can you send me the source drawing and your zipped iso-style. So I can look for it.
Regards
Bernd
Bernd G.
Senior Product Support Specialist
Maybe you can send the source drawing to me directly.
Bernd
Bernd G.
Ahmed1081975
in reply to: Ahmed1081975
Dear Bernd, Mail 1/2
PLs, find the attached file as your request
Ahmed Helal
This e-mail message and any attachments to it are intended only for the named recipients and may contain confidential information. If you are not one of the intended recipients, please do not duplicate or forward this e-mail message and immediately delete it from your computer. If you received this e-mail by error, please notify postmaster@metito.com.
The sender does not accept any liability for any loss, of whatsoever nature, however caused in the context of this message, which may arise as a result of Internet transmission.
Arun_Kumar_K
Hi, Pls don't waste by researching about this. It's a bug in isometric engine, If you use welding gap in plant space, you ll find this issue. Reconnect all the pipe lines after deselecting the weld gap and generate isometric. Weld gap, slopes are only a eye wash in plant 3d space.
”Boost
