AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Impossible to have correct orthographic views when plates are in the 3D model
8 REPLIES 8
Message 1 of 9
985 Views, 8 Replies
We are experiencing problems performing simple orthographic views in Plant 3D 2013 (French version) when there are "plates" elements: these elements are not displayed correctly in the orthographic drawings (see attached file "20130513 - vue du 2D - plaques NOK.PNG"), yet in 3D, these elements are displayed correctly (see attached file"20130513 - vue du 3D - plaques OK.PNG ").
Almost always when we have elements "plates" in 3D, orthographic views are not correct.
We tried several things: command AUDIT and PURGE on the 3D dwg file, command AUDITPROJECT and COMPRESSPROJECT on the project, but nothing helps.
Therefore, we cannot make correct orthographic views on our project which is a serious problem for us.
What is the solution to this problem?
We opened a ticket to the Autodesk Support Service via our subscription but the only response we got at the moment is that the problem is known (!) and that we are not an isolated case but they have not yet solution.
I am therefore calling to the forum and users if they have ideas.
Thank you in advance,
Best regards,
Alexandre Devos
Bonjour,
Nous expérimentons des problèmes pour réaliser des vues orthographiques simples sous Plant 3D 2013 (version Française) lorsqu'il y a des éléments "Tôles" : ces éléments ne s'affichent pas correctement dans les mises en plan (voir fichier joint "20130513 - vue du 2D - plaques NOK.PNG") ; pourtant, dans le 3D, ces éléments s'affichent correctement (voir fichier joint "20130513 - vue du 3D - plaques OK.PNG").
Presque systématiquement lorsque nous avons des éléments "Tôles" dans le 3D, les vues orthographiques ne sont pas correctes.
Nous avons essayé plusieurs choses : CONTROLE et PURGER sur le dwg 3D, AUDITPROJECT et COMPRESSPROJECT sur le projet mais rien n'y fait.
Nous ne pouvons donc pas réaliser de vues orthographiques sur notre projet ce qui n'est pas sans poser de sérieux problèmes.
Quelle est la solution à ce problème ?
Nous avons ouvert une requête auprès du Service Support Autodesk via notre souscription mais la seule réponse que nous avons eue pour le moment est que le problème est connu (!) et que nous ne sommes pas un cas isolé mais qu’ils n’ont pour le moment pas de solution.
Je fais donc appel au forum et aux utilisateurs s’ils ont des idées.
Merci d'avance,
Cordialement,
Alexandre Devos
Tags (2)
8 REPLIES 8
Message 2 of 9
Bernd.Gerstenberger
Hello Monsieur Devos,
The plates were corrupted. I have repaired your drawings and could create a valid ortho drawing. The project is too big for the forum. I will send it to you separately. Here I have attached a snapshot of the result.
Please, inform me if this works for you.
Best regards
Bernd Gerstenberger
Bernd G.
Senior Product Support Specialist
Message 3 of 9
in reply to: Bernd.Gerstenberger
Hello Mr Gerstenberger,
Thank you for your response but which command should I use to "repair" the drawing ?
Best regards,
Alexandre Devos
Message 4 of 9
The only answer I hadfrom Autodesk Support Service is that we have to recreate manually all plates in our project which doesn't show correctly in orthographic views. Our project contains hundreds of plates !
Autodesk Support Service told me it will be now treated by the development department but who knows when will we have an answer that will permit to have correct orthographic views.
Does other users experiments similar problem with 3D objects not correctly shown in orthographic views ?
Plant 3D doesn't seems to be a mature software and you are thinking of changing for something else. We cannot continue with a software that is sold for featurees that doesn't work.
Thank you in advance for you answers,
Alexandre Devos
Message 5 of 9
Arun_Kumar_K
Need solution, this issue is an irritating one. We have more than 300 plates in plant3d, not a correct solution to edit manually in ortho. This is an intelligent software not a raw Autocad.
Message 6 of 9
in reply to: Arun_Kumar_K
Arun,
I agree with you : Autodesk should release a hot fix ASAP.
Don't hesitate to create a case in your Subscription Center so Autodesk knows lot of people have the problem and need a solution.
Alexandre
Message 7 of 9
same thing here.
Waiting for a soution ASAP
Message 8 of 9
Arun_Kumar_K
Yes, I had logged a case in 2013 release itself, again a new case is created. Looking for Autodesk reply for this issue.
Message 9 of 9
elad_u
Hi
We have the same problem but with  L profiles as well as with plates .
I found that for L profiles the displacement of the profile is exactly the same all over the project, and also in the same direction.
The size of the unwanted displacement is 28.68421053 mm , upward.
Now that I know that it always the same size, the simple (but frustrating) solution is to lower the profile/plate in 28.68421053 mm downward from the elevation it's supposed to be .
Anyone who has this problem - please check that it is the same measurement. Maybe it will help Autodesk to find and correct this problem.
For the plates we are using the footing command "_PlantSteelFooting" which gives us good results
regards,
Elad.
”Boost
