AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Import STP to Plant 3D 2012
8 REPLIES 8
Message 1 of 9
Mudbay
2765 Views, 8 Replies
Hi
Isn't there a way to import STP-files to Plant 3D 2012 or MEP 2012? We will not update to 2013 until this winter.
/Mattias
8 REPLIES 8
Message 2 of 9
dave.wolfe
in reply to: Mudbay
You should be able to use Inventor Fusion 2012 to convert the stp file to dwg.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 3 of 9
Mudbay
in reply to: Mudbay
Is it not limited to 30 days of use?
Message 4 of 9
dave.wolfe
in reply to: Mudbay
No it shouldn't be.  I thought it came with AutoCAD 2012.  If not you should be able get it here: http://labs.autodesk.com/technologies/fusion/
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 5 of 9
david.flores
in reply to: dave.wolfe
We are using Autocad Plant 3D 2015. We have successfully imported STP files into our projects.
Message 6 of 9
dave.wolfe
in reply to: david.flores
In AutoCAD 2013, they increased the functionality of the IMPORT command so that stp files could be imported directly.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 7 of 9
LTOrion
Would you be able to give me a quick guide of how to convert step file to dwg using AutoCAD Plant 3D?...Without using Inventor.
Thank you.
Message 8 of 9
dave.wolfe
in reply to: LTOrion
Download a trial of 2016, start the IMPORT command, change the file type to stp. Save the block/dwg to whatever version you need (2010).
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 9 of 9
LTOrion
It worked great.
Thank you.
”Boost
