AutoCAD Plant 3D General DIscussion
Valued Contributor
vannmannen
Message 1 of 6 (839 Views)
Import / Export SPEC to Excel
839 Views, 5 Replies
12-16-2011 01:38 PM
Hi. My company just purchased plant 3D and it looks like a great package.
Issue: when I key-in information for a straight asme tee in the spec editor, there are 3 columns where you can manually input wall thickness.
Exporting the spec to excel: I only get option to key-in wall thickness in 1 column (and not 3 separate columns like in the spec editor). When importing the file back to spec editor, no wall thickness information I keyed-in is reflected in the spec :smileysad:
What to do?
Employee
rajsekarpillai
Message 2 of 6 (809 Views)
Re: Import / Export SPEC to Excel
12-19-2011 12:19 AM in reply to: vannmannen
The dimension parameters can’t be edited though Excel spread sheet.
The only workaround that I could think, use the Catalog editor to set the dimension values and add the components into Spec again.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Plant Solutions - AEC
Valued Mentor
ybogdanov
Message 3 of 6 (788 Views)
12-19-2011 03:42 PM in reply to: rajsekarpillai
Or Catalog Builder (version beta) and than export the excel to exist catalog.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Employee
rajsekarpillai
Message 4 of 6 (785 Views)
12-19-2011 05:55 PM in reply to: ybogdanov
The Catalog builder is not editor of existing Catalog. The Catalog builder is very useful when you create new Catalog.
Thanks & Regards,
S. R. Rajasekaran
Product Manager
Valued Contributor
Jorgen1990
Message 5 of 6 (663 Views)
06-20-2012 06:37 AM in reply to: vannmannen
Hi! I'm facing the same problem. Is there still no better solution that typing wall thicknesses in in the catalog editor? I have an EN fittings catalog (elbows, tees, reducers) where I want to add wall thicknesses and even more, I want to create each size with multiple wall thicknesses to choose from. Assigning the wall thicknesses manually in the catalog editor would be enormously time consuming (key in wall thickness->"all ports have the same properties"->"save to catalog" for each single part in the catalog). Isn't there any workaround to get to enter the wall thichnesses in Excel?
Cheers,
Jörgen
Valued Contributor
Jorgen1990
Message 6 of 6 (655 Views)
06-21-2012 05:36 AM in reply to: Jorgen1990
And also, in the spec editor, when I want to duplicate one size in a part family and click "duplicate size", I expect the dimensions and long descrition (size) to remain the same, but somehow these fields are all blank after duplicating, so "duplicate size" button gives the same results as "new size". Is this some kind of a bug? I am using Spec Editor 2013.
Jörgen
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
