Is it possible to import or convert 3D model from Plant 3D to CAESAR II or CTAPTfile (or any other programms for structural calculation)? There are opportunities to convert from PDMS, Plant 4D, Cadworx, but is it possible from Plant 3D?
The export of PCF to CAESAR is possible with CAESARII5.0 version. The present versions, doesn't support the PCF eventhough the option is available to Import.
For this, do the following:
1. Convert the PCF into CAESAR II version 5.0. Open the file and then save it.
2. Open the CII file (saved in 5.0) in present version.
Dear Arun,
Thank you for sharing. Could you clarify a little more? Does that mean we need a Caesar II Version 5.0 to open the PCF output from Plant 3D and then have the latest version of Caesar open that CII Version 5.0 file?
Tim
@Arun_Kumar_K wrote:The export of PCF to CAESAR is possible with CAESARII5.0 version. The present versions, doesn't support the PCF eventhough the option is available to Import.
