AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Import 3D model to CAESAR
3 REPLIES 3
11950 Views, 3 Replies
Is it possible to import or convert 3D model from Plant 3D to CAESAR II or CTAPTfile (or any other programms for structural calculation)? There are opportunities to convert from PDMS, Plant 4D, Cadworx, but is it possible from Plant 3D?
3 REPLIES 3
KenFauver
Yes. You can export to PCF file for import into Caesar. You can also export to an SDNF file to import the steel into STAAD and other structural analysis programs.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
Arun_Kumar_K
in reply to: KenFauver
The export of PCF to CAESAR is possible with CAESARII5.0 version. The present versions, doesn't support the PCF eventhough the option is available to Import.
For this, do the following:
1. Convert the PCF into CAESAR II version 5.0. Open the file and then save it.
2. Open the CII file (saved in 5.0) in present version.
tzhng.lim
in reply to: Arun_Kumar_K
Dear Arun,
Thank you for sharing. Could you clarify a little more? Does that mean we need a Caesar II Version 5.0 to open the PCF output from Plant 3D and then have the latest version of Caesar open that CII Version 5.0 file?
Tim
Tim Lim
Design Manager
THESB
”Boost
