AutoCAD Plant 3D General DIscussion
Active Contributor
rchiasson
Message 11 of 13 (111 Views)
Re: IGS extension
02-04-2013 06:49 AM in reply to: joaquinr
After importing the IGS file following the steps stated above, saving the file, it still is at 14Mb. After doing this you can then go through the steps doing the PLANTPARTCONVERT
Are you going to be using this valve multiple times or is it a one time use component. If you are going to be using this valve frequently, you WILL run into model size issues and performance issues. I highly recommend not using this for your modeling and instead build the valve in Plant 3D using existing valve components.
Product Support
gersteb
Message 12 of 13 (106 Views)
Re: IGS extension
02-04-2013 06:59 AM in reply to: joaquinr
In 2013 you can use the IMPORT command. Just type it in the command line. A browser will pop up. Select IGES for the file type and browse to your igs-file. You don't need here the subscription advantage package.
Bernd Gerstenberger
joaquinr
Message 13 of 13 (93 Views)
Re: IGS extension
02-04-2013 10:39 PM in reply to: joaquinr
thank you very much everyone for your answers to my questions.
one more problem that I have taught to solve, one more thing I have learned
joaquin rubio
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
