AutoCAD Plant 3D General DIscussion
joaquinr
Message 1 of 13 (641 Views)
IGS extension
641 Views, 12 Replies
01-31-2013 05:35 AM
good morning.
I have some equipment in IGS extension. I can not convert perfectly to Plant 3D solids.
as can be done properly to avoid mistakes?
thanks
buenos dias.
tengo unos equipos en extension IGS. No consigo convertirlo perfectamente a solidos para plant 3d.
como se puede hacer de manera adecuada para no tener errores?
gracias
joaquinr
Message 2 of 13 (602 Views)
Re: IGS extension
02-04-2013 04:56 AM in reply to: joaquinr
Active Contributor
rchiasson
Message 3 of 13 (605 Views)
Re: IGS extension
02-04-2013 05:21 AM in reply to: joaquinr
Can what ever software you used to create the IGS file export to dwg? That would be your best option if you want to use something that has been built in another software.
Ahmed1081975
Message 4 of 13 (601 Views)
Re: IGS extension
02-04-2013 05:24 AM in reply to: rchiasson
I Exported To DWG but now the Capacity of the File Became 19 MB how i can Uploading To you
 Ahmed Helal
Active Contributor
rchiasson
Message 5 of 13 (597 Views)
Re: IGS extension
02-04-2013 05:36 AM in reply to: Ahmed1081975
This may also help.
http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=15500470
If you have the model in dwg format, you can convert it into equipment.
Product Support
gersteb
Message 6 of 13 (598 Views)
Re: IGS extension
02-04-2013 06:11 AM in reply to: rchiasson
Hi Joaquin,
Do those steps to import the igs-file into your Plant3D-projekt:
  • Open your projekt and the drawing in which you want to add the igs-file
  • Use the command IMPORT. A browser will open. Change the data file type to IGES and browse for your igs-file
  • The import will be done in the background. When it is finished you will be notifiied by a bubble at the bottom right.
  • This bubble includes a link. Click on it and zoom to all. You see now the imported iges-file but it is still a couple of stupid surfaces.
  • Now use command PLANTEQUIPMENTCONVERT. It it is in the start ribbon, group 'equipment'.
  • A dialog box pops up where you can decide which kind of equipment you want to create (see snapshot)
  • After creating, select the new equipment and open the properties. As you can see in the second snapshot, your iges-file is now a specific equipment in your project.
Let me know, if this helps.
Regards
Bernd
Bernd Gerstenberger
Ahmed1081975
Message 7 of 13 (594 Views)
Re: IGS extension
02-04-2013 06:16 AM in reply to: gersteb
this Valve Not Equipment, it mean he have to use   PLANTPARTCONVERT  insted PLANTEQUIPMENTCONVERT
Ahmed Helal
Active Contributor
rchiasson
Message 8 of 13 (589 Views)
Re: IGS extension
02-04-2013 06:27 AM in reply to: Ahmed1081975
Yes, my mistake, you would use the PLANTPARTCONVERT to create the valve.
Though, I don't recomend this because of the size of the file. It is nice to use components that are already created, but the high level of detail that is usually in those sorts of models will severly affect the performance of Plant. If there is a way for you to shrink wrap it (similar to what Inventor does) out of what ever software it was created in to reduce the file size, that would be highly recommended if you are dead set on using the valve, or just use the valves in the software and adjust it for the appropriate length.
Product Support
gersteb
Message 9 of 13 (588 Views)
Re: IGS extension
02-04-2013 06:31 AM in reply to: Ahmed1081975
Hi Ahmed,
You are right: this is a valve. Sorry for this misinformation.
So here are the steps for a valve:
  • Create a new drawing and save it.
  • Create a block using command BLOCK
  • Use command PLANTPARTCONVERT. Add the two ports
  • Now open a catalog in your spec editor
  • Create a new component and select the option 'Custom - AutoCAD DWG Block based graphics'
  • Select valve in the category type.
  • Fill all the other fields
  • Select the model... This is your new block.
  • Save the new component to the catalog.
  • Add this component to one of your project specs.
  • Now you can add this via spec viewer in your project
Please, let me know if this helps.
Regards
Bernd
Bernd Gerstenberger
joaquinr
Message 10 of 13 (583 Views)
Re: IGS extension
02-04-2013 06:43 AM in reply to: rchiasson
Dear Sir, We have installed the 2013 version of AutoCad, that is why we have no permission to install the "Subscription Advantage Pack for AutoCAD 2011 Products ". What we have to do to make possible to read the IGS extension in this case? Best regards, Benito Joaquin Rubio Fernandez-Cienfuegos aqualia infraestructuras Delineante/ Dpto. Delineacion Calle Federico Salm?n, 13 - 28016- Madrid Tel. +(34) 91 417 95 10 111111111> - Fax +(34) 91 417 95 08 333333333> www.aqualia-infraestructuras.comwww.aqualia.eswww.fcc.es333333333>111111111>
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
