AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Identifying as "Revised"
5 REPLIES 5
TRdesigner82
448 Views, 5 Replies
I'm looking for a good way to identify parts of a pipe line as "Revised". We are about to push out our first revision using Plant 3D and I'm not really sure of the best way to do this. I was hoping there would be a REVISED status in addition to the NEW, EXISTING, and DEMOLITION. Can a REVISED status be added somewhere? I was also wondering if using a REVISED layer would be the best route. We aren't producing isos, just issuing pdf of drawings along with the project dwgs and Navisworks models. Any ideas or suggestions would be appreciated. Thanks in advance...
5 REPLIES 5
jabowabo
in reply to: TRdesigner82
Changing the layer could be problematic if you have layer automation turned on in the project settings. The items will be forced back to the automation layer settings when the project is refreshed. You can add a 'Revised' status option by adding it to the status property picklist but you might run into problems with Iso and/or report filtering. I think the best way to go would be to create a new picklist property called 'Revision', give it numbers 0 thru ~10 as options and set it to default to 0.
patpat79
In the set up, edit the list that contain the " new, existing, etc." or create n new property name it revised create a list like " yes or no" or as mentioned by jabowabo, create a property that identifies your revision number. Thanks
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
That sounds like a good approach.
(If that answered your question, please mark it as an Accepted Solution.)
Martin Stewart
AEC Support Specialist
TRdesigner82
in reply to: jabowabo
By adding a REVISION property, is there a way to get that to trigger some visual difference in the model? Maybe change the color of the components that have the REVISION property set to something other than 0.
patpat79
Yes there is, set your added property "revision" as the " assign color by" query. Just go to the project setup, layers and colors category. I hope it works. Thanks
Best Regards,
Pat Andres
GHD Manila
”Boost
