I want to keep the function of an Elbow becomes a Tee as I continue to route from the cross on Elbow
This feature works when I use the spec CS150. But when I made a new custom spec this functionality ends?
Where do I find the settings for this feature?
"The attached images are when I use the CS150 spec"
All the best regards & Thanks!
Christian Figved
NTI CAD Center AB
Sweden
the "branch table" (in the spec - use the editor to set one up) tells plant which type of fitting to use at a tee
in your custom spec did you include any tee's to match your elbow? (same size and connection port (socket or threaded)
