AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
[I need your help] I can not find GUID or Value properties.
1 REPLY 1
597 Views, 1 Reply
I "AutoCAD Plant 3D 2014" and "Autodesk Navisworks Manage 2014" is used. (64-bit)
I have a complex plant drawings.
In order to test this using Navisworks read drawings.
After that, "Crash Detective" was used.
As a result, the crash site was found
But the drawing is too complex "AutoCAD Plant 3D" was not found in the conflict area.
Therefore, the value of the object's properties in Navisworks I confirmed. (GUID value and the Value value)
But "AutoCAD Plant 3D" Value value value in the GUID was not found.
(I use it the Properties menu and the Data Manager menu)
"AutoCAD Plant 3D" value in the GUID value or Value I would like to know how to find.
(I like MSSQL DB is not used.)
If this article does not understand, click the link below.
It will help your understanding.
http://blog.daum.net/utalpian/2236536
Tags (1)
1 REPLY 1
h_eger
Hi dogyeom,
please use in NavisWorks Properties only the TAB "AutoCAD".
see Picture:
r.
Hartmut
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
”Boost
