I try to open report design but i can not and jumps this error, and do not know what the problem is if I need to download a file or software extra.
Thanks.
I havent encountered that problem so far. I think you can try to create a new report template and try if it would generate the same error.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
I try create a new report but jumps the same error, maybe i need select one option specified but i don't know.
Try opening existing out of the box report. See if the problem still occurs.
Best Regards,
Pat Andres
GHD Manila
Already tried and nothing, not open and get the same error, probe with windows 7 and there if it works and my pc have windows 8.1, will that is not compatible with windows 8.
Thank you
