AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Huge directory for tool palettes
6 REPLIES 6
GSC_HAYA
916 Views, 6 Replies
Hello
Today I've seen that the dirctory for the tool palettes became huge dimensions over 2 GB.
I think this is caused when switching the dynamic tool palette on/off. The palettes and the pics (bmp) will be copied into the directory every time I switch on.
(I don't need the palette for the piping specs, but for the pipesupportspec.)
How can I prevent these blow up of the directory?
Thanks Guido
Plant3D 2022 German
WIN10 Pro
6 REPLIES 6
Dan.Scales
in reply to: GSC_HAYA
Hi
I can't reproduce this here.
Could you provide the exact steps that cause the tool palette folder to increase in size?
Dan
Dan Scales
dave.wolfe
Seen this a bunch. My main recommendation is to turn PLANTDYNAMICTOOLPALETTE off. You can build a non dynamic support palette, or turn it on only when needed. Whatever you do, if you have dynamic palette on, do not have network tool palette paths.
I haven't been able to find out if this was fixed in 2014 or not. Basically, I'm not a big an of tool palettes for the type of content we use in Plant.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
GSC_HAYA
in reply to: Dan.Scales
I don't know why and when P3D copies all the files into this directory. May be it depends on the network path like Dave wrote...
I have turned the palette on and off this morning, and the directory did not increase....
Plant3D 2022 German
WIN10 Pro
GSC_HAYA
in reply to: dave.wolfe
Hello Dave
how can I create an own palette with the parts of the 'pipesupportspec'?
G
Plant3D 2022 German
WIN10 Pro
GSC_HAYA
...and here a pic from the directory...
Plant3D 2022 German
WIN10 Pro
Dan.Scales
If you disable the dynamic tool palettes you can still use the support spec by renaming the palette before disabling.
Dan
Dan Scales
”Boost
