AutoCAD Plant 3D General DIscussion
Valued Contributor
3 Kudos
Post 1 of 6
How to use LAPPED FLANGE?
687 Views, 5 Replies
01-11-2013 12:16 AM
I do not get to the bottom of this and I have tried all sorts things in Plant 3D.
My spec has got LAPPED FLANGE (RF/LF), STUB END (RF/BE) and all valves are RF/RF.
The STUB END in Plant 3D has got a LAP connection by default. In the model this STUB does not even show a connection point on the flange side. It appears as a connector. How can I make this work?
Pic 1 shows no snap-point at flange side
Pic 2 shoes snap-point on the welded side of flange
Hi Trygve,
I have looked for the properties of the flange and valve which have attached here. So for a valid connection it is defined in your project that the NominalDiameter, the PressureClass and the Facing of the connected ports are the same.
For your flange I can see that the properties are
for the port S1:
NominalDiameter = 8
PressureClass = 150
Facing = FF
for the port S2:
NominalDiameter = 8
PressureClass = 150
Facing = no value
For your valve the values are
for the port S1:
NominalDiameter = 8
PressureClass = 150
Facing = RF
NominalDiameter = 8
PressureClass = 150
Facing = RF
So the facing for the valves and the flange are different. You have to redefine your properties here, so a match is possible.
Please, inform us if we could help you.
Regards
Bernd
Employee
52 Kudos
Post 2 of 6
Re: How to use LAPPED FLANGE?
01-13-2013 02:56 PM in reply to: vannmannen
Are you trying to connect to an END osnap? Try the NODE osnap.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Valued Contributor
3 Kudos
Post 3 of 6
01-15-2013 07:32 PM in reply to: TomislavGolubovic
Thanks for your suggestion.
The components connect when I use the NODE snap ut I get error message and there is a leakage. See attachment.
Employee
52 Kudos
Post 4 of 6
01-15-2013 09:35 PM in reply to: vannmannen
The error message is telling you to check the 3 properties. Check one against the other and see what the difference is. When you find the conflicting properties, you'll have to take steps to rectify it, either by editing the properties again or the connection rules.
Tomislav Golubovic
Product Support
16 Kudos
Post 5 of 6
01-18-2013 01:21 AM in reply to: vannmannen
Hi Trygve,
for the port S1:
NominalDiameter = 8
PressureClass = 150
Facing = FF
for the port S2:
NominalDiameter = 8
PressureClass = 150
Facing = no value
for the port S1:
NominalDiameter = 8
PressureClass = 150
Facing = RF
NominalDiameter = 8
PressureClass = 150
Facing = RF
Regards
Bernd
Bernd Gerstenberger
Valued Contributor
3 Kudos
Post 6 of 6
01-18-2013 01:45 AM in reply to: gersteb
I have found a solution to this problem.
The thing is that the lapped flange is RF in my piping spec while the default Plant 3D catalog only offer FF facing for lapped flange. Did a duplication of the FF lapped flange and changed facing to RF.
Voilà !!!!
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
