AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to use ladder types
1 REPLY 1
762 Views, 1 Reply
Hi, good morning
How are made, or where can i found other ladder types for plant 3d?
In ladder set up dialog,only "type1" can be choosen.
I need a ladder like the attached image.
Can i modify the "type 1" ladder and save it as "type2"? How it`s made?
Thank you very much
1 REPLY 1
quentin.contreras
The structural content for the ladder type 1 is the only one that is editable and cannot be saved as something different for modification. If you are needing another ladder design you will have to manually create a 3D model for it.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
”Boost
