AutoCAD Plant 3D General DIscussion
Active Contributor
lyowbeen
Message 1 of 13 (1,114 Views)
how to show the "Insulation Line" in the iso
1114 Views, 12 Replies
09-02-2012 10:31 PM
In the 'IsoConfig.xml' file, there are some contents like below:
<Insulation InsulationLineLayerName="Insulation Line" HeatTracingLineLayerName="Heat Tracing Line" InsulationTracingOffsetDistance="0.1531" UseDoubleLineInsulation="true" UseOffsetLineInsulation="false" />
 I don't know what does the "Insulation Line" mean, and how to show that in the iso.
In addition, the "Heat Tracing Line" is OK.
Anyone can give me some ideas? Thanks!
Change the "UseOffsetLineInsulation" from false to true (as show below), this will display the inuslation in the ISO.
UseOffsetLineInsulation="true" />
The ISO will look like the one attached in the Pciture.
Product Support
Venkatesan.A
Message 2 of 13 (1,111 Views)
Re: how to show the "Insulation Line" in the iso
09-02-2012 10:46 PM in reply to: lyowbeen
Venkatesan.A
Support Specialist
Product Support
Active Contributor
lyowbeen
Message 3 of 13 (1,107 Views)
09-02-2012 11:43 PM in reply to: Venkatesan.A
Thanks.
But I think what your pictures shows is the "Heat Tracing Line" but not the "Insulation Line", because the option UseDoubleLineInsulation="true" can't control it. Besides, this line use the "Heat Tracing Line" layer in the "iso.dwt".
Active Contributor
lyowbeen
Message 4 of 13 (1,098 Views)
09-03-2012 12:26 AM in reply to: Venkatesan.A
Thanks! I have found the point.
thaipham
Message 5 of 13 (623 Views)
12-24-2013 06:06 AM in reply to: lyowbeen
do you khow how to resize the ISO Insulation symbole, the size is to big for me, even I was scale down to 0.5 in the Iso theme, I can not scale down more than that, otherwise all other symbole will be too small. please see the pix.
Active Contributor
Slepe
Message 6 of 13 (424 Views)
04-18-2014 06:53 AM in reply to: thaipham
Is it possible to show heat tracing line and Not insulation/insulated text but not the Insulation line?
When you use false-status it doesn't show either line but I wan't to show heat tracing line
and when you don't use Insulation button it shows correct but Not insulation/Insulated sign will not appear?
Has extension 2 something to this?
Version is Plant 2014
New Member
marian.barsony
Message 7 of 13 (346 Views)
05-20-2014 06:02 AM in reply to: lyowbeen
Hi could you send me a solution. I just want to see insulation line.
Member
sethb
Message 8 of 13 (330 Views)
05-20-2014 11:47 AM in reply to: Slepe
Have you considered putting Heat Tracing line and insulation line in two separate layers and then turning off the insulation layer?
Active Contributor
Slepe
Message 9 of 13 (321 Views)
05-20-2014 12:09 PM in reply to: lyowbeen
Tracing and insulation are in different layers. You can turn off them from theme Block configuration ( same where you setup BOM etc.). When you turn off example insulation layer and run Your isometrics it won't show line but it shows breaks.
New Member
marian.barsony
Message 10 of 13 (304 Views)
05-21-2014 12:07 AM in reply to: Slepe
Thanks for your help, but I need to show insulation line in isometric drawing.
I have set it up in isoconfig.xml
<Insulation InsulationLineLayerName="Insulation Line" HeatTracingLineLayerName="Heat Tracing Line" InsulationTracingOffsetDistance="3" UseDoubleLineInsulation="false" UseOffsetLineInsulation="true" />
 But it still not work.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
