AutoCAD Plant 3D Forum
How to mapping the symbol p&id with the part 3d - Control Valve
1 REPLY 1
pinarj
1010 Views, 1 Reply
I need to insert a control valve but do not have a 3D part, I try to connect with a 3D part but I can not create 3d mapping class in the project settings, I have searched but can not find anywhere
there any way to accomplish this
Thanks.
1 REPLY 1
marodilp
in reply to: pinarj
Hello!
You can find the mapping here:
Project Setup/Plant 3D DWG Settings/P&ID Object Mapping
Under P&ID Classes:
Engineering Items/Instrumentation/Inline Instruments/Control Valve
Here you should give a Plant 3D Class Mapping. For Example Pipe Run Component/Inline Instruments, but I think you make you life easier if you use Pipe Run Component/Valve/(All subtypes)
Is it okay now?
Cheers,
Laszlo
”Boost
