AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to install Navisworks Manage 2012 as component from Suite
1 REPLY 1
vtu_admin
366 Views, 1 Reply
Hi there,
i have installed 3d Plant and Autocad from Design Suite Ultimate 2012. Now I also need to install Navisworks Manage from this suite but i can't find the installation files to add this to the existent installation.
Can someone please help me how to add this without installing the whole suite?
Thanks a lot.
1 REPLY 1
Just double click setup.exe again and it will take you to the installer, which gives you the option to select which parts of the suite you want to install, one of which would be NW Manage
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
”Boost
