AutoCAD Plant 3D General DIscussion
Active Contributor
lyowbeen
Message 1 of 3 (535 Views)
how to get the plant-dwg-file's name in isometric
535 Views, 2 Replies
06-14-2012 07:24 PM
HI All.
I got a trouble when I create an iso.I would like to insert the plant-dwg-file's name into the iso drawing.For example,if the plant-dwg-file's name is 'PipeInAreaA.dwg',what I want to insert is just 'PipeInAreaA'.
For that, I tried to click "Title Block Attributes", selected 'Drawing Properties→Drawing Name',and inserted it on the table cell.But that didn't work.
So my problem is that how to get the plant-dwg-file's name in isometric.
Thanks!
Been
Sorry but the mapping of the dwg file name to the iso title block is not feasible at the moment as the dwg file is just a stand alone drawing right now.
This has already been identified as a wishlist and our developers are looking into it.
But I can suggest a work around which is to use the LDT (line dimension table) option, with this option you can use the excel spreadsheet to map the model dwg name to the Iso title block..
Product Support
Venkatesan.A
Message 2 of 3 (529 Views)
Re: how to get the plant-dwg-file's name in isometric
06-14-2012 08:31 PM in reply to: lyowbeen
Venkatesan.A
Support Specialist
Product Support
Active Contributor
lyowbeen
Message 3 of 3 (519 Views)
06-14-2012 10:01 PM in reply to: Venkatesan.A
Maybe the LDT is no better than modify the .pcf file  manually,I think.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
