AutoCAD Plant 3D General DIscussion
Valued Contributor
4 Kudos
Post 1 of 5
How to Create Parametric Graphics?
749 Views, 4 Replies
10-13-2011 08:55 AM
Hi to everyone,
Anybody knows if is possible to create a Custom Plant 3D Parametrics Graphic to use in Catalog Editor / Create New Component?
If is possible, can you say How?
Thanks.
Employee
52 Kudos
Post 2 of 5
Re: How to Create Parametric Graphics?
10-16-2011 01:18 PM in reply to: batone79
The Catalog Builder (in beta stage) might be of help:
http://autocad.autodesk.com/?nd=plantcatalogbuilder
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Valued Contributor
4 Kudos
Post 3 of 5
10-18-2011 09:29 AM in reply to: TomislavGolubovic
thanks I will test it..!!
Active Contributor
3 Kudos
Post 4 of 5
09-24-2012 08:12 AM in reply to: batone79
Did you get it to work?
I was wondering the same....
In 2013 this should be part of the software.
Valued Mentor
18 Kudos
Post 5 of 5
09-24-2012 12:52 PM in reply to: snijdam
I would suggest, taking an exisiting catalog - SAVE IT under a different name, then delete all parts.
create a part ( I created pipe, 45 elbows and 90 elbows to start )
export it to excel <file> <export to catalog builder>
edit the parameters <in excel> ( you have to unprotect the worksheet usually )
run the catalog builder
build the catalog
and test it... and repeat editing the parameters untill you understand how they work ( for the most part )
This is basically what I did untill I got a rough understanding on how to build parametric parts.
it seems to work fairly well for imperial parts, it totally bugged out trying to make metric parts.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
