AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to Create Parametric Graphics?
4 REPLIES 4
batone79
1817 Views, 4 Replies
Hi to everyone,
Anybody knows if is possible to create a Custom Plant 3D Parametrics Graphic to use in Catalog Editor / Create New Component?
If is possible, can you say How?
Thanks.
4 REPLIES 4
The Catalog Builder (in beta stage) might be of help:
http://autocad.autodesk.com/?nd=plantcatalogbuilder
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
thanks I will test it..!!
snijdam
in reply to: batone79
Did you get it to work?
I was wondering the same....
In 2013 this should be part of the software.
JohnHolder
in reply to: snijdam
I would suggest, taking an exisiting catalog - SAVE IT under a different name, then delete all parts.
create a part ( I created pipe, 45 elbows and 90 elbows to start )
export it to excel <file> <export to catalog builder>
edit the parameters <in excel> ( you have to unprotect the worksheet usually )
run the catalog builder
build the catalog
and test it... and repeat editing the parameters untill you understand how they work ( for the most part )
This is basically what I did untill I got a rough understanding on how to build parametric parts.
it seems to work fairly well for imperial parts, it totally bugged out trying to make metric parts.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
”Boost
