AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to create Isometric symbol for rotameter?
2 REPLIES 2
sharon
1431 Views, 2 Replies
There is a rotameter which is an inline asset in the routing.
Isometric symbol has been created but the drawing is split into 2 and where the lines connect the rotameter symbol is also wrong.
How to create rotameter symbol which connects correctly to the port and also don’t split the drawing? how can I get an iso like below (edited with Autocad)
2 REPLIES 2
serafin.albiero
in reply to: sharon
You need to joke with Iso Symbol Type, change it to TYPE=ELBOW !!  Even if your custom part is a Valve, Instrument...
By entering: TYPE=ELBOW,SKEY=EUBW you will get a correct isometric (tested over here), but with Bend-180Return block, so save it as a new block and edit it with your needs!
Serafin A. Albiero Jr.
sharon
in reply to: serafin.albiero
Thank you very much, Serafin. That really works.
Sharon
”Boost
