There is a rotameter which is an inline asset in the routing.
Isometric symbol has been created but the drawing is split into 2 and where the lines connect the rotameter symbol is also wrong.
How to create rotameter symbol which connects correctly to the port and also don’t split the drawing? how can I get an iso like below (edited with Autocad)
Solved by serafin.albiero. Go to Solution.
You need to joke with Iso Symbol Type, change it to TYPE=ELBOW !! Even if your custom part is a Valve, Instrument...
By entering: TYPE=ELBOW,SKEY=EUBW you will get a correct isometric (tested over here), but with Bend-180Return block, so save it as a new block and edit it with your needs!
