AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to create 6'-0" insulation long on the lon pipe
6 REPLIES 6
thaipham
711 Views, 6 Replies
I just want to insulate the instrument element of temperature, I just need 6'-0" long insulation and it can be generated to Iso drawing.
thanks.
6 REPLIES 6
Could you please post a screen shot of the model of what you're referring too?
Martin Stewart
AEC Support Specialist
thaipham
in reply to: thaipham
I have a long pipe non insulated (ex. more than 20 ft.). I have a temperature element (TE) attach to the pipe, and I want to insulated that element with 6 ft. long. I want to know how to create in the model and then generate an ISO.
see attachment for the screen shot,
thanks for reply.
This is a great question. Seems like this would come up more often. In the model, there does not seem to be a quick and direct way to do this. I will bring this to the development team’s attention. I encourage you to also send this directly too. Product enhancement recommendations can be submitted here:
Contact Us - Feedback - Products
There may be a workaround of sorts for this. Try these steps:
  1. Add welds to the pipe at the end locations of the insulation length.
  2. Change the property of those welds to ‘existing’
  3. Now select that segment of the pipe and give is a unique Line Number Tag or change to Unassigned (this is temporary).
  4. For that same segment, add your insulation. Toggle Insulation Display On if necessary.
  5. Select the insulated segment and change the Line Number Tag back to original number (Insulation remains as placed).
(See attached image)
However, that just gets you the appearance you’re after on the 3D model. It doesn’t translate over to the Iso –and now shows existing welds you don’t need.
Maybe other community members have some additional ideas on workarounds. But this is a great product enhancement idea.
Martin Stewart
Another situation commonly found would be on exterior lines which run into a building.  Client specs would indicate "extend insulation ___ mm inside building".  As you note, normally this would be done by creating an additional uninsulated pipe with a weld.  Being able to partially run insulation along a pipe would be very beneficial.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
thaipham
Thanks for viewing and replying with suggestions.
Great work around. We have a lot of jobs with Personel protection and this will work well. We just need to work with the line number to be the same as the rest of the line.
”Boost
