AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to copy/duplicate an existing Plant 3D project under SQL Server
9 REPLIES 9
Message 1 of 10
aldevos
6194 Views, 9 Replies
Hello all,
I'm trying to find a way to copy/duplicate an existing Plant 3D (2013 SP2) project under SQL Server.
I've already asked Autodesk Technical Support but procedure they gave me doesn't work. I get an error in the end when opening the "duplicated" project (see attached - sorry in French). Autodesk Technical Support recommended me this not officially supported procedure (!) :
1] Create backups of the existing SQL project databases.
2] Backup the project folder and files.
3] Rename the existing project : http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21185815&linkID=14116967
4] Restore the original project.
Please don't answer me to create a new project using settings of my current project and then add manually files to the project. Our project contains around 400 files (P&ID and 3D files) with a complex tree so adding them manually would take long each time we want to duplicate our project to do some migration test to Plant 3D 2014.
Alexandre Devos
9 REPLIES 9
Message 2 of 10
dave.wolfe
in reply to: aldevos
First copy the files on the network to a new location.
Go to the installation folder and look for pop project maintenance.exe. that will let you select the copied project and will copy the SQL server db and link them to the copy.
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 3 of 10
dave.wolfe
Sorry, autocorrect got me. Pnpprojectmaintenance.exe.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 4 of 10
aldevos
in reply to: dave.wolfe
Hi Dave,
Thank you very much, this works great. It's a shame this procedure is not more explained in Plant 3D 2013 or 2014 Help!
http://docs.autodesk.com/PLNT3D/2014/ENU/index.html?url=filesPLNT3D/GUID-46AB1EC0-40C1-4625-ADC5-21B...
http://docs.autodesk.com/PLNT3D/2013/ENU/index.html?url=filesPCR/GUID-46AB1EC0-40C1-4625-ADC5-21B5E5...
To sum up, here's what to do to copy a Plant 3D Project under SQL Server:
1/ Copy your project files in a new directory, for example C:\Project_Old to C:\Project_New
2/ Open PnPProjectMaintenance.exe tool located in installation directory of Plant (for example: C:\Program Files\Autodesk\AutoCAD Plant 3D 2013 - French), use third option to copy database by selecting C:\Project_New\Project.xml, specify new server/database name and finally execute
3/ Open copied project in Plant by opening C:\Project_New\Project.xml
Alexandre Devos
Message 5 of 10
andre.a.de.souza
Is this valid for P3d 2015?
I am looking for this file.. searched from root and it is nowhere to be found in the system..
Has AutoDesk removed it?
Message 6 of 10
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 7 of 10
Message 8 of 10
Sorry Dave, just extending the question if I may.
What if the project is SQLLite?
Message 9 of 10
I too would like to know how to do this with SQLite. Is the process the same?
I was using Plant 3D's "copy settings from an existing project" option but it never copies all the settings so I started just copying the project folder.
This works BUT you have to open up the database dcf files and change the project name in all those dcf files under PNPProject. Then there are about 10 xml files who's directories don't change and those all have to be updated as well.... It's a huge pain is what I'm getting at.
If there's an easier way please do tell us. 🙂
Thank you.
Message 10 of 10
samyg
Hi Dave,
What about the XML files in the new directory that still refer to the old one?
Is it a must to edit them manually to the new directory?
”Boost
