In the event when a different standard component is introduced into an establish pipe line class, can this be done so that the correct component is captured in the BOM?
Eg. If line class "ABC" specifies ANSI 150# with ANSI std pipe OD, however ONE component supplied for this line is only available in JIS standard which has a different dimension for welding to the pipe (i.e. JAPANESE pipe OD), hence to accomodate this component, custom made flange with welding dimensions matching ANSI std pipes c/w JIS flange OD and bolting configuration to match the "ONE component " needs to be utilized, would PLANT 3D be able to accomodate this? And how to overcome this abnormality
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Thanks for reply....what i mean is if I create a ASTM-PIPE and then I will connect a JIS Flange....any settings I need to fixed it? Like Piping Connection Setting....
Thanks...
Best Regards,
Pat Andres
GHD Manila
Hi patpat79,
I know that is feasible....but in reality it happens specially in our current project the pipe we use is astm std. and some LJ flange we used is DIN & JIS Std. because of valve we used....Why i'm asking this situation for isometric generation if can generate it in plant 3d and also I am a new user of Autocad Plant 3d.
Amador
Best Regards,
Pat Andres
GHD Manila
