AutoCAD Plant 3D Forum
How to connect ASME Valves with bondstrand spec
1 REPLY 1
373 Views, 1 Reply
Hi all,
i 've a problem, i 've downloaded the BONDSTRAND CATALOG but now i wish to connect an ASME wafer valve.
I 've added to the bondstrand spec the Bolts and Valves but impossible to connect stubend flange to valve.
What can i do
Thanks for your  responses.
Grégory
1 REPLY 1
TomislavGolubovic
What are the end codes of the two items you want to connect?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
”Boost
