AutoCAD Plant 3D General DIscussion
luoyong20061289
Message 1 of 2 (943 Views)
Accepted Solution
How to change the displayed unit of pipe diameter NS to MM(millimeter)
943 Views, 1 Replies
12-18-2011 06:56 PM
Hello all,
Does anyone know if there is anyway that i can set or change the displayed pipe diameter unit NS to MM ?
By default, i get NS when i create an isometric drawing,i use metric in my work,so i'd like to change NS to MM.You can see this on the image attached. So if anyone know how to do it, pls tell me.
Problem solved, go to the isoconfig.xml file, find<PropertyChangeScheme Name="Size" AnnotationStyle="Standard" Format="{0} NS" Grouping="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="NotBoltWeldFlangeGasket" Field="Size" Placement="Along" />
change the value of Format “{0} NS” to “{0} MM”.
luoyong20061289
Message 2 of 2 (926 Views)
Re: How to change the displayed unit of pipe diameter NS to MM(millimeter)
12-18-2011 10:16 PM in reply to: luoyong20061289
Announcements
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
