Hi
I didn't find how to change CONNECTION-REFERENCE format in P3D2013.
(I'm working in isoconfig.xml )
On isometric, at the end of the line connected to an equipment , the reférence of Tag of equipment + the equipment nozzle tag + lb of the nozzle are concatened.
If I want just the equipment tag and the ND of the equipment nozzle how to configure the format ?
Thank
Solved by Dan.Scales. Go to Solution.
Unfortunately the CONNECTION-REFERENCE attribute is hardcoded and cannot be changed.
I will log a wish with our developers for the ability to edit this connection text.
Dan
Thanks Dan,
This save my time to find a solution.
I hope a quick devellopement ot this functionality
Sam
Hi Sam,
Another approach to get the result you need could be:
EndConnectionScheme Name="EndConnectionsEquipment" AnnotationStyle="Standard" Format="CONNECTED TO\P\P\P{0}\P{1}" LeaderStyle="AlwaysCorner" Filter="EndConnectionsEquipment" Fields="CONNECTION-REFERENCE CO-ORDS" />
I hope this helps.
Dan
It still isn't working for me. Perhaps I don't have the correct annotation properties. I can't find them documented anywhere and obviously I'm not a very good guesser. I've also found that this is maybe a known issue with Autodesk and version 14 may fix it?
Edited by
Discussion_Admin
It's actually not possible to set this up in the isoconfig.xml. You need to use the project setup dialog.
The available properties and formatting are available here:
http://docs.autodesk.com/PLNT3D/2013/ENU/filesPCR/GUID-E5AB172A-9696-455F-B698-252CEA84CC07.htm
per Dan's answer above.
