AutoCAD Plant 3D Forum
How to add non-standar nozzle ?
1 REPLY 1
757 Views, 1 Reply
Aspiration tube drawing. Example ø560mm. I created non-standard pipe and fittings. But the problem. Not same diameter.
Sorry for bad english.
1 REPLY 1
you will need to edit the Nozzle catalog.acat (from your Cpak Common Folder)
use the catalog editor and select .acat from the type dropdown when you go to open a catalog.
”Boost
