How to add label on the 3D pipe (such as high pressure dangerous...). I try to use the "imprint", but the program say the 3D is not a 3D object.
There is any simple to put label on the pipe, like the inventor?
I've seen a Lisp that creates 3D text. You can also follow these steps:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=4248500&linkID=9240615
The problem is the pipe is not considered 3D object. I try this methed. it does not work.
It does work, the link I posted is talking about unioning the extruded parts of the text together. I found a link to the Lisp file that lets you create 3D text easily.
Maybe I did not say it clearly. The lisp you provide is for 3D text. I am trying to add text to the pipe surface. To make it look like someone add label to the pipe surface.
