AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How to Add In line number a insulation type and Insulation Thickness
3 REPLIES 3
jvelezt
2067 Views, 3 Replies
Hello All
We are work  my piping class Based in PIP Line number rules, but in this rules the number lines included the insulation types and insulation thickness
see below
3 REPLIES 3
quentin.contreras
in reply to: jvelezt
You have the ability to add additional information from the project property values within your project to your pipe tags. This is explained in the About Tag Formats in the P&ID help section. Also, there is a great P&ID Customization document that will explain in more detail some of the customization you are wanting as well.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
jvelezt
in reply to: quentin.contreras
Quentin.contreras
This is the solution
ho.dadgar
How can I add a new type of insulation to the spec of plant 3d, for example L type insulation.
”Boost
