AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
How do you mark flange as existing?
1 REPLY 1
jlott
437 Views, 1 Reply
In a previous post the question was asked"
"How do you add a bolt and gasket set to an open flange (not connected)"
Answer was given:
Just insert mating flange and "Mark as existing"
My Question:
1 REPLY 1
JoeKay
in reply to: jlott
Select the 'existing' flange. Then on the Properties bar, there should be 'Status'. Change to Existing.
Now if you don't want that to show up in BOM. In the Report creator you'll need to query 'Existing' out.
Hope that helps.
”Boost
