This is in Plant 3D 2013...
I understand that every valve body is governed by an SKEY in order to show the valves symbol. Now I am trying to get a Actuator symbol to show up for certain valves? It seems that there should be a way to have actuators operate on a seperate skey that is not dependent on valves, since often the valve is made, and then multiple actuators are applied to the same valve. So far, the only way I see to make an actuator symbol show that I want, is to make a whole seperate set of valves for the other actuators. Deciding an actuater after the fact is useless, as it does not change the output of the ISO. Is there something I am missing here?
Is version 2014 any better in this aspect? I sure hope so... I don't mind doing a little programming, but I hate doing unnessecary block making for parts that should be easy to make. There are 10+ actuators in this project. I sure hope I do not have to make the valve library 10+ times larger. It should be so simple... Who in the world decided that people would only want one actuator for a certain type of valve?
Oh yeah, every single globe valve will be hand operated... Genius!
First step: Download Whitepaper - De-Mystifying AutoCAD Isometrics
Second step: in the following file, IsoSkeyAcadBlockMap.xml check out section VALVES all SKEYs for the faucet body.
third step: In the section "Valve operator symbols" you find all SKEYs for the drives.
fourth step: in the section "VALVE SPINDLE TO SKEY SKEY" you can find the mapping of the valve body and the drives as they are shown in Isometrics.
here you can create your combinations you even as you need them.
regards
Hartmut
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
I made an skey generator to make sure that I do not overlap any SKEYs that are for the other stuff. So, If anyone wants it. Message me, and I will get it to you. I wish someone would have done it for me, so I made it and am willing to dispense it.
