So I'm just starting out with plant 3d and have a problem while creating a P&ID in P&ID PIP workspace. In the book I'm using, one of the things I am asked to do is go to the tool pallette/fittings tab/ and pick on an ecc. reducer and insert on a line in the drawing.
The problems lies with the fact that in the fittings tab I only have 2 catagories - speciality piping items and nozzles. Neither of which have a reducer in them. I think it (fittings tab) used to have more items to chose from how can I reset it of rebuild the library w/attributes and ability (in the reducers case) to break a pipe line on the P&ID to allow me to give the two sides of the reducer different properties, tag assignments, etc.
BTW I have went thru all the different tool pallettes and none of them have sufficient tool pallette libraries for getting to detailed.
PIpe spec?
I was using a book that doesn't start explaining that until ch.5 I'm still in ch.2 I haven't set the specs yet.
the book
"AutoCAD Plant 3D 2014 for Designers"
By Sham Tickoo
