How can I supress co-ordinates in isometric? only Elevation will be there.
How can I bring the complete Pipe Tag in Isometric drawing, now it is coming "Line No.-Pipe size-Spec".
I want it should come like "Size - Spec. - Service - Line No."
Solved by Dan.Scales. Go to Solution.
Try this:
Hope this helps,
Dan
Thanks Dan
supress of co-ordinates its working as per your advise.
what about the other query?
"How can I bring the complete Pipe Tag in Isometric drawing, now it is coming "Line No.-Pipe size-Spec".
This can also be configured in the isoconfig.xml. This time by editing the LineNumberScheme to this:
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{1}-{0}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC Service" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}-{1}-{2}" LineFormat="{0}" />
One thing to note is that if the Service has not been assigned then no isometric line number will be written to the isometric.
This is a link to the Help file section on this:
http://docs.autodesk.com/PLNT3D/2014/ENU/filesPLNT3D/GUID-B60BFFD0-1700-4B68-9A31-6BF9A9968ECC.htm
You may also find this useful:
http://www.pdoteam.com/2012/05/customizing-line-display-in-plant-3d-isometrics/
Hope this helps.
Dan
As per the Following Link
I am able to bring the Service in my Pipie tag but,
1. Size is not coming.
2. IN SOME PIPE MODEL SOMETIMES it is coming like "--FW-117", IN ANOTHE PIPE LINE it is coming "-MSBK08.50-FW-117".
3. BUT BOTH THE CASES SIZE IS NOT COMING IF "LINE DISPLAY"
4. IN DATA MANGER "LINE DISPLAY" COLUMN IS NOT COMING.
PLEASE HELP ME OUT.
Did you set the nominal size/spec in the line group properties?
Sorry !
Still proble is there........
Somteimes spec is coming but in all cases Size not coming.
